Where to mount switch
Old Sep 4, 2005 | 01:21 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
hey guys. I just did the mod to override the speed limiter and i need some Ideas for where to mount my switch. i already have it wired over to the drvers side of the car, i just need some ideas where to mount it.
Thanks,
Kyle
Old Sep 4, 2005 | 10:20 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
As I add in more switches, I'm going to notch the center console (near the power window switches) and poke them through there.
Old Sep 5, 2005 | 12:11 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
i mounted it beside the ashtray
Old Sep 5, 2005 | 12:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Why would you make it switchable?
Old Sep 5, 2005 | 03:26 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
If he did it the only way I know of (that doesn't involve PROM burning), then he has to cut the VSS signal from the transmission which will afect a lot of other things such as the speedometer not working and shiftpoints will be strange. It's not something that you're supposed to leave disconnected for too long.
Old Sep 6, 2005 | 12:28 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Exactly, i only swtich it when I have to and when i'm aproaching 105 or so, then turn it off immediatly after what ever reason i'm going so fast for. If that makes any sense
Old Sep 9, 2005 | 03:10 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
ahhh, if you cant look at the speedo whats the point . when does our speed limiter come on; i have had my 1986 2.8L up to 130 on the way up I-5 in the "grapevine".
Old Sep 9, 2005 | 09:41 AM
Car: 86 T/A
Engine: HSR 355
It's much lower the in the TBIs from what I've read.
Old Sep 9, 2005 | 03:10 PM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
Switch mounting
Here's where I have all of my switches mounted
jhawkeye
May 25, 2022 06:33 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
355sbcTPI
Aug 19, 2015 04:38 PM
