Anyone wanna take a guess on this one?
Old Sep 4, 2005 | 05:57 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Was just wondering if and what this plugs into. It's runs right above the aldl port under the dash, has a pink wire/black wire and a purple wire. I was looking for a short to find out why my ACC fuse keeps blowing and ran acrossed it just hanging down, don't think it's related with the fuse blowing but just wondering what it is.
Old Sep 4, 2005 | 05:58 PM
Car: 92'Camaro RS
Engine: a loud one
one more
Old Sep 4, 2005 | 07:11 PM
Vader's Avatar
Does your cruise work?
The GAGE circuit uses pink/black for the power wiring. Most of th eACC circuit power uses orange wiring.
Old Sep 4, 2005 | 07:20 PM
Car: 92'Camaro RS
Engine: a loud one
No...Cruise doesn't work..... I pulled the fuse box down and noticed the orange wire goes into the ACC port,that's why i figured they weren't related. If that is for the cruise control,what does it plug into to? I'll be darn if i can find where it plugs into, i musta looked for a half hour and couldn't find where it went, besides it can only stretch so far. My cigarette lighter,power hatch,locks,mirrors and dome light don't work. I checked all the wiring to the mirrors,door locks and hatch...all seems to be clean.
Old Sep 4, 2005 | 07:38 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
my guess is the brake switch. auto trans? purple wire goes to the tcc, i think... brake switch is kinda hard to see up under the dash cuz a lot of stuff in front of it.
Old Sep 4, 2005 | 07:39 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Check your brake switch (if it's still there).
Old Sep 4, 2005 | 07:43 PM
Car: 92'Camaro RS
Engine: a loud one
No....manual tranny
Old Sep 4, 2005 | 07:57 PM
Car: '91 Z28
Axle/Gears: 323's
i don't know if gm makes harnesses specifically for the manual and auto trans cars, but that's what that is for. so my second guess would be that it was integrated in to the harness anyways. it controls the tcc switch in an auto trans and is not used for a manual trans. so, it's just there kinda hangin' out...
Old Sep 4, 2005 | 09:00 PM
Vader's Avatar
Cruise brake or clutch switch?
Old Sep 4, 2005 | 09:18 PM
Kwiksilverz28's Avatar
I think clutch or cruise plug. My 82 had the wiring for an automatic, so when I went from 4 speed to auto, I just had to plug the plug into the shifter and I had reverse lights and all.....
Old Sep 4, 2005 | 10:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is the connector for the TCC and would go to the brake switch.
Old Sep 5, 2005 | 02:07 AM
Vader's Avatar
I thought the TCC used a purple wire instead of light blue.
Old Sep 5, 2005 | 07:09 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I agree that it does look blue in the picture but he says in his post that it is purple.
Old Sep 5, 2005 | 07:26 AM
Car: '91 Z28
Axle/Gears: 323's
so maybe my second guess was right... so are the harnesses made all the same anyways and depending on what options are installed (other than engine options) all the connectors would be in place?
Old Sep 5, 2005 | 09:43 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
no, there are at least two different types of wiring harnesses: auto and manual. for one, manual cars dont come with the plug that goes into the 700R.
not really related, but just proving im not making stuff up: https://www.thirdgen.org/techbb2/sho...hreadid=299156
Old Sep 5, 2005 | 10:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
David, the simplest way to do this is to trace the purple wire and see if it goes to pin "E7" of the bulkhead (C100) connector on the driver side. If it does then it is for the TCC, if it doesn't then let us know.
BTW SaintedCorrupt, some models of the camaros and firebirds were designed to come with either the manual or automatic transmissions. On those models wiring was included in the harness to handle both transmissions. If you wish to put a manual transmission into a car that originally was not designed for it then yes you would have to re-wire the car to accommodate it.
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
