big problem
Old Sep 8, 2005 | 11:02 PM
MAR-STAR's Avatar
Car: 85' IROC-Z
Engine: 350 tpi
big problem
I have a 1985 IROC that I stupidly ran with no mass air flow sensor for about 3 months.
right before it decided to die on me and not start at all it started pinging and back fireing.
that same day I bought the sensor put it in and noticed it would still ping and backfire if I kicked it down even just a little. I parked left it sit for the night and the next day it would not start at all.
I could spell strong un-burned gas but it would just crank away.
al checked for spark and i had it . c
an any one help
Old Sep 9, 2005 | 12:01 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I'd pull a plug or two and see if they look normal. Could be a lot of things, but probably a load of carbon deposits in the chambers. Try holding the gas all the way down and listening for any fire. If you have fouled plugs and/or weak spark, this should lean out the mix a bit and make it easier to start.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
