what feeds power to the fuse block?
Old Sep 10, 2005 | 02:42 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I need to know which terminal on the firewall connector sends 12v. to the fuse block. I got rid of my factory harness in the process of ditching the TPI. On the stock setup it comes from the starter through a fusbible link through the harness and to the fuse panel.
Old Sep 10, 2005 | 07:19 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
get a test light and start probing
Old Sep 10, 2005 | 10:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try pin "A4" of connector C100 on the driver side firewall.
Old Sep 11, 2005 | 12:22 PM
Engine: LB9/383
no battery or anything in the car. Thanks though.
Engine: LB9/383
Thank you
Old Sep 11, 2005 | 04:37 PM
Engine: LB9/383
FWIW, I found my shcematics and pin A4 feeds the ignition switch and switched circuits and G5 feeds constant circuits.
Old Sep 11, 2005 | 09:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes I know, there are many wires that branch off and feed a multitude of systems from "A4" that include the ignition switch and the fuse block.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
stalkier
Aug 13, 2015 12:59 PM
