I get nothing when I turn the Key!!
Old Sep 15, 2005 | 11:01 PM
88camaroIROC's Avatar
Car: 1988 Camaro IROC
I'm having a problem with my '88 IROC. When I turn the key to on there is no power, no dome light, no nuthin'! The battery is only 3 mos old. Has anyone run into this before? Could this be the starter solenoid? Please HELP!!
Old Sep 15, 2005 | 11:21 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Start cheap have the battery checked and see if theres any loose cables to your battery.
Old Sep 15, 2005 | 11:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the voltage at the battery or the condition of the fusible links to the starter solenoid. Even new batteries have been known to go bad and if it is bad then you might want to look at having the alternator tested as well. BTW, the dome light should come on when you open the door and not when you turn the key to the "ON" position. If it doesn't then the bulb is missing, burned out, has a bad circuit, or the battery is "FUBAR"
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
Kaweh
Aug 9, 2015 02:54 PM
