power windows
Old Sep 19, 2005 | 01:47 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
power windows
can someone tell me y my power windows are slow in rolling up and sown is it bad motors or not enough juice
Old Sep 19, 2005 | 03:15 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Motors going bad probably, the next stage will be stopping every
few inches when the internal circuit breakers start tripping.
Old Sep 19, 2005 | 07:32 PM
Firebat's Avatar
Replace your window motors.
Old Sep 23, 2005 | 10:34 PM
UnderKule's Avatar
Car: 91' RS Camaro, 05' Stratus, 02 quad cab Dakota
Engine: 305 in the Camaro
Take the inner panels off and lube the tracks and any other parts that look like they need it. Clean them out first though. Sometimes when they get gunked up they just run slow because of build up in the tracks. Done it twice and believe me the can of cleaner/degreaser and new lube is way cheaper and easier than tracks and motors if you don't need them yet. Give it a try, If it doesn't work at least the panels are already off so you can replace the motors.
L8R,
J.P.
Old Sep 24, 2005 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Like UnderKule said.
JamesC
Old Apr 7, 2006 | 03:01 PM
Jforce2409's Avatar
So just the general cleaning and relubing of the tracks really helps that much? A friend of mine had SLOW windows and thought it was the motors so he replaced them ( a very unpleasant task) and unfortunately they still run JUST as SLOW...
Old Apr 7, 2006 | 03:12 PM
JamesC's Avatar
The window motors are slow compared to other cars, true; however, you can speed them up a bit with a thorough cleaning, which will probably prolong motor life as well. Check the following link for other helpful info:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Apr 7, 2006 | 07:17 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Clean and lube all moving parts, for me, an added dose of silicon spray lube afterwards and every six months keeps 'em moving. Consider upgrading the wiring and cleaning all electrical connections associated with the power windows. The PW electrical system, like the headlight wiring, appears to be marginally designed, at best.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
