Passenger headlight wire not powered
Old Sep 30, 2005 | 07:16 PM
Okra's Avatar
Car: '88 Firebird Formula
The passenger side headlight on my 88 firebird formula will not go up and down. The headlight turns on fine, but it will not move. The wire that plugs into the headlight isn't getting any power. Do I need to replace the headlight module?
Old Oct 1, 2005 | 06:58 AM
Vader's Avatar
If you manually raise the headlight door with the ****, does the door lower when the lights are turned off?
Old Oct 1, 2005 | 04:44 PM
Okra's Avatar
No, it doesn't go back down either.
Old Oct 1, 2005 | 08:47 PM
Vader's Avatar
If the motor ground is intact, you need to meter the power connections to the motor (while connected, if possible). If there is nothing, work backward to the headlight control module.
Old Oct 2, 2005 | 09:26 AM
Okra's Avatar
Alright, thank you!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
