weird starter problem
Old Oct 4, 2005 | 05:02 PM
venom's Avatar
Car: 1992 RS
Engine: 305tbi
Axle/Gears: 3.08
Ok so heres the problem.
About a week ago I went to start my car and when I turned the key, everything went out. No lights no battery power, nothing. A couple seconds later everything came back to life, so I tried it again, and got the same result. After a few tries, the power stayed off for a while. So I got under the car and the solenoid was hot. I bench tested it, and sure enough, after a few tries it locked up. So I got a new one and put it in. But when I put it in, I left the feedback wire loose by mistake and had an intermitten overcharging problem. So I fixed that Sun. and everything seemed OK But when I went to start it after I got home yesterday the same thing started happening again. Only this time on the 3rd or 4th try it started. Is it possible that I got another bad starter, or somthing else?
Old Oct 5, 2005 | 12:49 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Make sure all of your grounds are tight and not corroded.
Old Oct 5, 2005 | 04:23 PM
venom's Avatar
Car: 1992 RS
Engine: 305tbi
Axle/Gears: 3.08
ya I did all the normal check the grounds and connections when I fixed the loose wire Sun. And now the battery gauge has slowly been falling in the last couple days. Usually when Im driving its up a little past 13 but now its right on it, and its slides a little below 13 when braking or stopped. Im just wondering if it all has somthing in common
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
CORV3TT3
Aug 23, 2015 11:26 AM
sreZ28
Aug 14, 2015 07:48 PM
