door locks dont work. relay just clicks
Old Oct 8, 2005 | 12:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
My power door locks dont work from either side of the car and the relay just clicks. I replaced the relay already and nothing changed. The unlock/lock buttons on the drivers side both work because when I press either of them the relay clicks. The passenger side on the other hand only makes the relay click on the lock button. the unlock button seems to be dead in the water. This car has been sitting for a year or so undergoing other major modifictaions. Could it be that BOTH my door lock actuators could have somehow craped out on me?
Old Oct 8, 2005 | 01:13 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
They are both grounded via the same point, maybe its a loose connection?
Old Oct 8, 2005 | 01:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
hmmm. could be since I have a few grounds handing loose under the dash rightnow since I am not done installing the dash. Would you happen to know for sure where the ground is?
Old Oct 8, 2005 | 01:24 PM
Car: 86 T/A
Engine: HSR 355
They are grounded directly via the unit themselves. They screw right under the kickpanel to the sheet metal underneath.
Old Oct 8, 2005 | 02:44 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i have the same problem with mine and still havent figured out what the deal is. i know the actuators work and its a new relay and i have new switches. just need time to trace it out to see. hey bottled does your horn work also cause mine doesnt work. just wondering if it has anything to do with it
Old Oct 8, 2005 | 02:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
Mt horn currently doesnt work since I broke some plastic thing inside the column that the white platic thing with the wire and spring attached to it goes to. The horn circuit is not on the same circuit as the door locks.
Old Oct 8, 2005 | 09:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds like one of the common problems on our cars. Years of accumulated dirt and grease gum the mechanisms up. Try cleaning and lubing (both the locks and power window tracks with WD-40 and white grease). Since you'll be inside the door anyway, check the following link for some other suggestions:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Oct 8, 2005 | 09:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
In regards to the grounding point for the door locks in your car, they do not ground through the unit itself to the car frame as firebirdjosh has mentioned. They dropped that concept in 1988 when they switched to a different relay. In your car it is located under the rear of the center console if you have power windows and power mirrors and under the drivers seat if you don't.
Old Oct 9, 2005 | 08:41 AM
BOTTLEDZ28's Avatar
Transmission: A4
why in all he11 would GM run the ground for the door locks all the way in the middle of the car? Is it me or does that seem like a real dumb place? I will take a look in there and see what I can find. Idont recall there ever being a ground wire(s) in there that i had to ground but I will check. Thanks for the tip
Old Oct 9, 2005 | 08:54 AM
Car: 86 T/A
Engine: HSR 355
You beat me again Trickster! My stupid 86 being outdated...
Old Jul 28, 2021 | 07:15 PM
92chevysilver's Avatar
Re: door locks dont work. relay just clicks
Sorry I'm new to hear and don't know how to post. I have a 92 Chevy silverado and I bought it with no door handles so it has a door popper on it. It recently quit working and I don't what the problem is. It is connect to a remote so I can automating open the doors. It's jot working anymore and when I try and diagnosis I just get clicking in the relay. The passenger side has one also but has never worked. So I switch the wires for drivers side to the other relay and still get the clicking noise.. Please help
Old Jul 29, 2021 | 05:09 AM
OrangeBird's Avatar
Car: 1989 Firebird
First and foremost, this forum is only for 1982-1992 Chevy Camaro / Pontiac Firebird cars, you will need to find a Chevy truck forum to answer your question.
With that said, since your door poppers are aftermarket, your best bet would be to find out who manufactured the kit that was installed, and get the wiring diagram from them to use in your troubleshooting.
Good luck with it
Old Jul 29, 2021 | 02:00 PM
Good luck with it
Sorry!
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
