Lights dim at idle
Old Oct 12, 2005 | 08:20 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Lights dim at idle
when I am driving around, basically off idle the voltage is at 13.5. When I idle the voltage drops to 12.5, which i read from searches that is normal. The annoying problem is that at night when the voltage drops to 12.5 you can notice a slight dimming of the headlights and dash lights. Can this be corrected some how?
thanks, phil
Old Oct 12, 2005 | 11:12 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
i don't know, but you can see my lights flicker at idle if everthing is on.
Old Oct 12, 2005 | 11:16 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I do not believe the voltage should be that low with the engine idling. Sounds like the source of the problem.
Old Oct 12, 2005 | 11:41 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
according to my searches here. It is normal to go to 12.5V at idle.
Old Oct 12, 2005 | 12:13 PM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I see this every day on motors much newer than our cars, personally as long as they go to "normal" illumination as you rev up, i wouldnt worry.
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
