VSS wire?
Old Oct 15, 2005 | 11:52 AM
Kandied91z's Avatar
VSS wire?
anyone know where the VSS wire would be on a 91 z28? trying to tap my navigation into it and i don't have the manual with me this weekend? if anyone knows the color and approximately where it runs through that would be great!
Old Oct 15, 2005 | 12:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't know what your set-up was prior to your engine conversion but here are the color codings and the way the wires were run. The wires are purple and yellow and for a VIN T,F, & 8 they ran straight to the ECM pins "B10" & "B9" through the passenger side bulkhead from the VSS in the transmission. If you had the VIN E, the wire colors were the same but were routed through pins "D4" and "E4" of connector C100 on the drivers side bulkhead. They then ran to pin "A" & "C" of the VSS buffer under the dash on the passenger side, there are five other wires going from the buffer. Pink/black goes to gage fuse, brown goes to ECM, tan goes to instrument panel, red goes to cruise control module, & black/white is ground.
Old Oct 15, 2005 | 06:13 PM
Kandied91z's Avatar
very nice, i kept everything in line so that i could refer to my 91 manual just in case. you helped out perfectly, i appreciate it.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
Bryan F
Aug 27, 2015 07:28 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
