Does an MSD box replace the HEI module?
Old Oct 16, 2005 | 03:41 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Just what the subject says, this is for a non computer controlled HEI.
*before anyone says the 6al box is worthless, this is going in a 406, 11:1 compression, big heads, big cam, ect, ect. Not a stock lg4 LOL
Old Oct 16, 2005 | 04:30 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Yes, it can do. Just follow the instructions carefully. If you are missing them, go onto the MSD website and download them. When I did mine, I had trouble getting the trigger wires from the msd box through the dizzy cap and getting them secured well enough. Did it in the end though.
Ironically I have an 86 camaro lg4 with an MSD 6al box
Andy.
Old Oct 16, 2005 | 04:55 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Thanks for the help!
No offense about the lg4 thing... i've just seen a lot of guys get flamed for using the box's on here because they're "worthless"
Old Oct 16, 2005 | 05:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The MSD box will replace the 4 pin ignition module in a non-CCC distributor entirely.
It will not replace the ignition module in a computer controlled distributor. Firing the coil will be done by the box, but the timing functions of the module are still needed.
Old Oct 16, 2005 | 05:22 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
Just fyi msd has an excellent forum on their site. If you post a question the msd guys come back right away with an answer. I have a 6al with a mag pickup and adj timing control, they helped me out when I had a problem.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midias
Aug 15, 2015 05:07 PM
