Code 12, good or not good
Old Oct 22, 2005 | 02:26 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I thought code 12 was the code for normal, than I read that is also means the distributor is not talking to the ecm.
The old ecm got toasted, I bought a used one plugged it in and I am now getting a code12. I thought I heard someone say the code 12 can also be caused by a faulty ecm. What I can do to check this. It's the only code I'm getting. The check engine light is on during normal operation. I don't know if the car starts cause it's on the batt. charger but I don't think it will. Thx.
Ben
Old Oct 22, 2005 | 03:55 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Is there a procedure to check your ignition module?
My tach is acting funny too.
Old Oct 22, 2005 | 04:02 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Ben:
Code twelve 3 times means everything is AOK!
Old Oct 22, 2005 | 04:47 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Than why is my check engine light on all the time? It just stays on when the aldl connector isn't jumped. When I turn the key on, it flashes once, this means it sees the prom right? Then it just stays on. I jumped the aldl and it flashes the code 12 over and over, I counted at least 7 times.
Ben
Old Oct 22, 2005 | 07:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It means that your computer has taken a long vacation from which it won't be returning and is waving "BYE BYE".
Actually it sounds like you may have a short or broken wire somewhere between the ECM and the ALDL. It will be the orange wire going from pin "BA8" of the ECM to pins "E" & "M" of the ALDL through pin "J" of connector C207.
Old Oct 23, 2005 | 04:57 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i am in perpaetual awe at your knowledge of thirdgen wireing. were you on the design team or somthing?
Old Oct 23, 2005 | 07:34 AM
CrazyHawaiian's Avatar
Car: too many ...
He's the Trickster man, he knows all the tricks..
Would it be safe to assume the same thing if the SES light does not come on but you get code 12's over and over forever using the paperclip (but no codes using scantool)?
Old Oct 23, 2005 | 09:47 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Which of your cars is doing this and does the CHECK ENGINE light come on when you turn the key to the "ON" position?
Old Oct 23, 2005 | 12:37 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
I checked for a short from either connector (aldl or ecm) and I check for continuity. Both were good. The batt. was dead, I charged it last night, started it this moring, let it warm up turn it off and now there is no check engine light. Don't know what it was, maybe the dead batt. had somethin to do with it. I was testing it with the charger power which was 13v.
Thx for your help anyway.
Ben
Old Oct 23, 2005 | 06:02 PM
Car: too many ...
Its happening on my 89 IROC-Z (so 165 MAF TPI). I'm gonna go clear the codes and try again to make sure the Check Engine light is not coming on. I dont remember it coming on, but I want to double check. Thanks for the help Trickster.
Old Oct 24, 2005 | 08:41 AM
Car: too many ...
Yes the SES comes on when the key is in the on position (but not started). Sounds like its time for a new ECM ...
Old Oct 24, 2005 | 04:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sounds more like you can relax if I am reading your posts correctly. The SES light is supposed to come on when you turn the key to the "ON" position and go off after you start the car. If there are no malfunctions in the car for which the computer throws a code then the computer will throw nothing but a code 12 at you over and over until the cows come home or Hawaii freezes over and the surfers take up ice fishing.
Old Oct 24, 2005 | 06:43 PM
Car: too many ...
Oh, my bad then. I figgured this would be the perfect time to try the "going crazy" Smilie. Hahaha, looks more like an angry Smilie. Well, thanks for the good news Trickster. Really appreciate the help.
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
