Need help identifying harness and A/C conn!!
Old Oct 24, 2005 | 04:43 AM
Blazer79's Avatar
Car: 1986 Iroc-Z
Engine: Stock 305 TPI MAF w 148,000 mi.
Hello:
I'm swapping a 350 in my 1986 Iroc. Had a MAF 305 now I'm doing the MAP swap also. I'll be ordering a new computer harness for the swap since the old is too hacked up.
There's the square connector besides the brake booster that I have a diagram for, so no problem there.
My question is about the remaining harnesses:
There's a harness coming from a circle hole right besides the steering column. It has a hose, a square connector with plugs of different shapes, a flat, gray female connector with 5 terminals, and a weatherpack male connector with two terminals.
Can anybody tell me what are these for?
There's another harness right behind the engine, which I'm pretty sure is for HVAC. I did a search for a wiring diagram for this but only found one hosted on tripod and wouldn't work. Anybody have a diagram so I can figure out which connector goes where? BTW, previous owner had removed the A/C. I'm putting it back now.
I'll try to post more pics tomorrow so it's easier.
Any help greatly appreciated.
Attached Thumbnails Need help identifying harness and A/C conn!!-img_2559a.jpg
Old Oct 24, 2005 | 08:53 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The gray one is for the cruise control servo as is the vacuum hose. The hose runs to a switch on your brake pedal that kicks out cruise when you hit your brakes. The square one looks like it should hold a relay. Sorry I can't help more.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
Linson
Sep 21, 2015 01:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
buckshot63
Sep 10, 2015 09:15 AM
