Check Engine Light With Broken Speedometer
Old Oct 25, 2005 | 03:46 PM
Hoek01's Avatar
Car: firebird 1985
Engine: 305 tpi
I VE GOT A 1985 FIREBIRD 305 TPI . I TOOK OUT THE ORGINAL SPEEDO METER AND NOW THE CHECK ENGINE LIGHT IS ON, AND IT RUNS POORLY HELP?????? THX RENE HOEK-- AMSTERDAM -THE NETHERLANDS...
Old Oct 25, 2005 | 07:47 PM
Vader's Avatar
Welcome Aboard!
The original speedometer should have had a wire harness connector on the rear. That would have been the VSS. It was connected to the ECM to provide vehicle speed information. You'll need that input to enable the ECM to control the transmission torque converter lockup, the cooling fan shutoff, and possibly some of the IAC/stall saver programming on decel. If you have installed a speedometer without a VSS output, you may be able to install a separate VSS by using a speedometer cable splitter (like the type used on older curise controls) and a VSS on the second cable.
Old Oct 26, 2005 | 04:45 AM
Hoek01's Avatar
Car: firebird 1985
Engine: 305 tpi
speedo
do you know where i can buy a new one or second hand??thx dude
Old Oct 26, 2005 | 08:37 PM
Vader's Avatar
Have you checked our Classifieds section? You can view what is available, or list the item(s) you are seeking.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
