vats problem.......help please
Old Oct 29, 2005 | 04:42 AM
dennine3003's Avatar
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
I just got done with a engine swap. I put a v-8 tbi from a 89 camaro in a 85 camaro. I changed the wiring harnesses on the engine and under the dash. I bought a new ignition cylinder and key w/chip and a new vats module, so the module would read the new chip in the key. but it wont turn over or anything.
the gauges come on, but wont crank. Should I disconnect the battery and reset the ecm or what???? Please help, this is getting frustrating to the point I want to blow my car up.
Thanks in advance for any advice on this problem.
Old Oct 29, 2005 | 12:16 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Personally I'd bypass VATS until I get the engine running. Just one less thing to worry about.
Old Oct 29, 2005 | 11:37 PM
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
I found out it was the starter enable relay, it was missing, so Igot to go to the dealer on Monday and get one.
I used a fused jumper wire and it turned over.
I'm so happy right now
Old Nov 26, 2005 | 11:24 PM
restored92's Avatar
how do you do the junper thing
Old Nov 26, 2005 | 11:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Take a wire with a fuse in it and connect it between pins "A" & "E" of the starter enable relay connector.
Old Nov 26, 2005 | 11:53 PM
restored92's Avatar
how do you no which ones a and e are if nothing is marked on the only thing i think may be it(relay) square black with four wires and you can take out a white pin and pull the fuse out with four gold colored connectors
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
