No charge situation.. car stuck at friends house
Old Oct 31, 2005 | 09:29 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I finished my motor swap and all the wiring is the same... nothing has changed.
I got a new batt and alternator.... and the thing wont charge....wtf what chould i check
is it possible that i cannot ground properly to my aluminum heads( if so where to ground to)
can it be a bad starter solenoid( needs to be replaced anyhows) ie high resistance etc...
bad wires... im not sure wat wires are supposed to go to the solenoid but i put the ones with the big loops on the big bolt and the ones with the lil loops on the lil bolt... what wires should be where?!?!
Old Oct 31, 2005 | 10:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Is it the same type starter that was on the car before ?
May check your 'fan' fuse (20A) as well.
Old Nov 1, 2005 | 07:49 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
its the same starter but im not sure if its wired correctly.... but i put the wires back the only way they could go... i dunno... grr im find out tomorow
Old Nov 1, 2005 | 10:25 PM
deadbird's Avatar
Engine: TPI 305/ v6
Sorry about that bud.. I meant alt(ernator) but, apparently I pulled the alcohonym of alt., 'starter', out of my a** from somewhere and typed it instead
The (not sure if this is the correct term.. rectifier? -->) alt is powered/switched by the juice comming from the 'fan' fuse under the dash. This is a switched power supply. W/o power from here, the alt will not do much of anything.
Also check for +12v on the harness plug at the alt with the car on. If you don't have 12v on both (key on or running), there may be a break in the circuit somewhere.
Old Nov 1, 2005 | 11:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
That's a very good question about aluminum heads, I've never really thought about it. I'd try grounding somewhere else, run a ground from the alt to the chassis maybe? If the alt is spinning it should be charging the battery- is the alt decent quality? I've had new stuff come out of the box broken.
Old Nov 2, 2005 | 05:00 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: No charge situation.. car stuck at friends house
To the best of my knowledge (which isn't sayiong much, heh), aluminium is a somewhat better conductor of electricity over cast iron. I couldn't imagine that being a problem.
Old Nov 2, 2005 | 08:05 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
alcohonym
"alcohonym"...it's my new favorite word
Old Nov 2, 2005 | 08:31 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
ALRIGHT PPLS THANKS FOR ALL THE HELP AND GOOD NEWS FOR ALL
SHES RUNNING
MYTH : you can actually ground to alum heads.... it works so yea
also i had my wiring all messed up so i fixed it... thanks anyhows
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Reborn756
Sep 4, 2015 03:42 AM
