Question about fuel pumps???????
Old Nov 7, 2005 | 01:48 AM
dennine3003's Avatar
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
I put a 305 tbi in a 85 Camaro. The motor came out of a 89 camaro. Should I change the fuel pumps around too?????? Put the v-8 one in my 85 and take my fuel pump that is in it now (it used to have a v-6 in it) and put it in the other car that I put the v-6 in??????
I'm just wondering cuz my car is hard to start, it takes about 3 times to crank it and it finally starts. When I turn the key to on I don't hear the fuel pump run to prime the system to start. but after I do finally get it to start I then can hear the fuel pump run, even after I shut the car off.
I have already changed out the oil pressure switch(it needed it, it was bad), and the fuel pump relay. Now I have no idea what to do now. PLEASE HELP!!!!!!
Should I switch fuel pumps, I don't know.......... Any information would be great.
Old Nov 7, 2005 | 01:50 AM
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
The 20 amp fuse by the battery is fine, so I ruled that one out.
Old Nov 7, 2005 | 12:14 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The V6 pump should run the V8 ok. In the Carter series the same pump is used for both the MFI V6 and the TPI V8s anyway. Why the pump doesn't come on with the ignition is probably a wiring problem, but it is running off the oil pressure switch for now. Don't know how relliable that will be in the long run.
Old Nov 7, 2005 | 02:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it isn't priming when he turns the key, it sounds like it might be a problem with the ECM. That is where the fuel pump relay gets its signal to prime the system. Either that or as mentioned. the wiring from the ECM to the fuel pump relay.
Old Nov 7, 2005 | 04:07 PM
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
Can I use a ECM from a 92 Camaro that had the same 305 TBI in it??????? or will I have to buy a new ECM?
Please let me know.
Old Nov 8, 2005 | 07:25 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Sounds like a bad pump relay. The reason it takes some cranking is because the fuel pump has 2 voltage sources, the relay and the oil sender sw. Above 4-5psi the oil sender sw closes and applys 12 volts in a parallel path with the relay to the pump. It's a very common problem. You need to crank the engine with the starter to generate the oil pressure needed to energize the fuel pump if the relay or it's connector is bad. Rarely does the ECM cause this problem.
Old Nov 8, 2005 | 07:50 PM
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
I checked all the wiring from the ecm to the feul pump relay and it's all good. Like I said before the fuel pump relay and the oil pressure switch is new. The ecm that is in it now looks like it came from a junk yard. I'm wondering if it could be the ecm. It's the only thing that I can think of. The ecm looks pretty rough anyway.
So let me know what I should do.
Old Nov 14, 2005 | 12:55 AM
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
sorry for taking so long to reply. It was the ecm, I bought a new one and it worked. Thanks for all the help guys.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
