need help BADLY!!!
Old Nov 7, 2005 | 10:24 AM
chingon88cam's Avatar
Car: 92 RS
Engine: 5.0 L03
need help BADLY!!!
Ok, i have a 91RS and just got a new tranny installed, i took it to get smoged and my electric fan wouldn't come on, well i figured out that it was the wrong fan and it rubbed the bottom of the fan shroud, so i installed a cheap aftermarket fan (wire to the ground & wire to fusebox) so it passed smog, well driving it back from my parents house i noticed that my voltage meter kept dropping rapidly... before i knew it i was on the side of the road (new battery, new alternator) i recharged the batter and unplugged the fan, i drove it home and the meter stilled droped, got home, shut the car off and it hasn't been started since (2 days ago). NO lose connections.
N E ideas, i need some, i have no car and the bus drivers went on strike.
HELP!
Old Nov 7, 2005 | 10:49 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Sounds like that new alienator has crapped out on you. Put a voltmeter on it when running and see what you got. We can start from there.
Old Nov 7, 2005 | 11:04 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Yeah i agree, start up the car and you should be reading 14 volts at the battery if not then your alt. is gone. Or you may have a short maybe arking to ground
Old Nov 8, 2005 | 02:48 PM
Car: 92 RS
Engine: 5.0 L03
alright, so i got a volt meter and it didn't read 14 volts it was beteween 11 and 12, so i went and got another alternator, i installed it and did the old trick of disconnecting the batt. while the car is runnin' and yes the car shut off as soon as i disconnected the batt. wires... could it be a ground??? or could it be 2 bad alternators. I have followed the wires from the alt. to see if they shorted somewhere, but everything seems to be fine. any suggestions will be greatly appriciated.
thanx
PS: busses still on strike!
Old Nov 8, 2005 | 03:46 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
You probably popped a fusible link on the line which excites the alternator. With the key on, probe the wires on the alt for power. There are a few.
Old Nov 8, 2005 | 03:51 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Didn't post the schematic. Here ya go!
Old Nov 13, 2005 | 09:29 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
your not getting these alternators from autozone or somewhere like that are you?
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
