"brights lever" all of a sudden doesn't engage?
Old Nov 12, 2005 | 10:10 PM
FrankenT/A's Avatar
Car: Trans Am
Literally of a sudden tonight, the bright lever doesn't engage. The turn signal engages, as does the wipers and everything but not the brights.
Should I replace the lever because it's 15 years old, or is it something in the steering column?
Old Nov 12, 2005 | 11:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, not neccessarily! You may just have a bad dimmer switch which is located above the ignition switch on the steering column under the dash or the rod that runs down the steering column from the lever to the dimmer switch might be bent or loose. Do a and you will find plenty of info that I have posted on this subject.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta_knight
Sep 17, 2015 03:48 PM
Jlanz55
Sep 9, 2015 09:09 AM
Glowsock
Sep 6, 2015 06:40 AM
