Is there anything i shoule clean or check/tighten under dist cap?
Old Nov 29, 2005 | 03:42 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am replaceing the iginition control module with accell one and i ws wondering while I am in there is there anything else I should check? Can I spray it with a cleaner? Can I put dielectric grease on all of the plug connections? thanks
Old Nov 30, 2005 | 01:17 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I wouldn't use a cleaner unless it's designed for electronics.
Dielectric grease never hurts, I use it on every connector I touch on my car. There is a 9/16 bolt that clamps the distributor in place. It's threaded into the intake manifold. I'd make sure this is tight and then check you timing after you all finished.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
TBRays98
Sep 6, 2015 05:05 PM
