90 rs cranks but won't start
Old Dec 1, 2005 | 06:12 AM
dinobravo's Avatar
Car: 93 chevy silverado
Engine: 5.7 bored 30 over
Transmission: 350 tubo
Looking for help for my dad! He reciently purchased a 90 RS 3.1. All parts replaced new w/t reciepts when bought: computer, nock sensor, distributor, coil, injectors, ignition switch w/t new chip key. The car will crank but not start. The injectors are not pulsating. It will run on starting fluid/gas and then 1 and 6 injector pulsates until fluid gone, then nothing. Tried to recieve codes but gives none? Had 2 other mech./tech work on it with no solution? Please help!
Old Dec 1, 2005 | 10:28 AM
spifman's Avatar
Car: 1986 Camaro RS
Engine: 305 V8
Transmission: 700r4 automatic
I've got the same problem, but with an '86, so no VATS to worry about. I got an ignition tester, a little device that plugs onto a spark plug wire, and will spark if the plugs are getting sparks or not. (doing it tonight, should narrow it down).
This lets you narrow it down to either a) plugs and wires, or b) from the distributor cap down. If it's a new cap, ignition coil, etc. and it doesn't spark, then I'm guessing it's the distributor itself. If you see a spark in the ignition tester, it's probably either the spark plugs or some of the wires.
Not a definate answer, but hope this helps.
Old Dec 1, 2005 | 08:49 PM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
fuel pump relay is what did it for me. car would crank and crank and crank and nothing
changed the relay and voila! It worked Give that a try
Old Dec 7, 2005 | 01:01 AM
spifman's Avatar
Car: 1986 Camaro RS
Engine: 305 V8
That actually did it for me... I found the relay over on the passenger's side, near the firewall. I also had to replace the spark plug wires, 'cause I was a) getting a weak spark, and b) oil had eaten through 2 of them (just got it, previous owner did it...).
Old Dec 12, 2005 | 11:55 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
How about the fuel pump fuse that is located next to the battery on the pass. side fender???
I am betting thats the culprit!
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Winchester1094
Aug 18, 2015 10:23 AM
