Testing power window motors?
Old Dec 6, 2005 | 05:45 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I've just recently acquired a very nice 1991 Firebird. However, the power windows are not working on either side of the car. How do I check the motors without actually digging into the doors so that I can find out if it's the window motors or just the window switches that need replaced? Is it as easy as applying 12 volt power to one of the wires going to the switches or is there more to it?
TIA!
Old Dec 6, 2005 | 09:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Testing power window motors?
TIA!
Yes it is, there are four wires to each switch;
Pink is hot
black is ground
dark blue is up window
brown is down window.
I would first check the pink wire with a multimeter and see if it is getting battery voltage with the key in the "ON" position.
Old Dec 8, 2005 | 05:39 PM
Thanks alot ... I'll give it a shot!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
