battery question
Old Dec 9, 2005 | 10:34 AM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
battery question
I was disconnecting the negative cable from my battery this morning and the drivers side headlight motor started spinning, is this normal for cars with flip up lights cuz this never happened with my montero.
Old Dec 10, 2005 | 11:30 AM
Vader's Avatar
No, that is not normal. I believe the '87 models still had the multiple relay control scheme for the headlight doors. The problem may be in the motor end switch (torque actuated).
Old Dec 10, 2005 | 04:57 PM
rjpbboi's Avatar
how would I go about correcting this?
Old Dec 11, 2005 | 01:32 PM
Vader's Avatar
Perform a using the terms "headlight" "motor" and "switch". You should turn up a lot of information.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
