dead circuit when plugged in
Old Dec 12, 2005 | 05:23 PM
pontiacsteve's Avatar
Car: 82 z28
Transmission: auto th350
Axle/Gears: stock
Would anyone know what would cause the circuit to go dead, when the wire (that is "hot") when NOT plugged into the choke heater on my 86 T/A. is attached to the choke heater.
Old Dec 13, 2005 | 02:26 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
If the wire has a greater resistance than the choke heater then it will do that. Most likely the wire or fuse or connector is worn out a bit. check the resistance from the battery to the "hot" wire.
Si.
Old Dec 13, 2005 | 05:04 PM
Car: 82 z28
Axle/Gears: stock
So that I don't leave anyone "hanging",here is what happened. On an earlier issue, my fan motor fuse kept blowing so I ran a new wire . What I didn't realize until tonight was that it also fed the choke circuit. I tied the old wire I cut, back into the new wire I ran and now everything is working, Apparently the wire that went through the fire wall was shorted and by leaving one end disconnected it still feeds the old circuit and the new wire feeds the other one,now both circuits are working properly. Thanks for all the input.
Old Dec 13, 2005 | 05:15 PM
iroc-si's Avatar
No worries, glad you got it sorted!
Si.
db057
Apr 28, 2019 07:45 AM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
andy74
Sep 3, 2015 08:41 AM
