brake light switch :(
Old Dec 13, 2005 | 05:45 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
man, i am so close to getting my car done and was checking all my lights and... NO brake lights! so i guess i'll be doing that today. already checked and have power to the switch itself, just nothing on the other side when i hit brakes, tail or hatch light. oh well - guess i know better now than to close up all the panels before i check everything, huh?
Old Dec 13, 2005 | 07:07 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am using a hotrod harness so it is wired differently. I used a Painless brake switch and screwed it into my linelock and ran the wires to it. Easy and clean. Hope this helps, but if you are all stock I guess it wouldn't.
Old Dec 13, 2005 | 11:05 AM
Car: '91 Z28
Axle/Gears: 323's
yea, i'm pretty much stock... i was just venting for the heck of it anyways. switch is already swapped out, piece of cake. that was probably my fault that it went bad, tho. i was doing some re-routing and cleaning up of the alarm system, and things just got jammed together and the switch was cocked in there. probably woulda' still worked, but put the new one in anyways. it's all better now, though...
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
