Need engine wiring help
Old Dec 13, 2005 | 01:08 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I just bought a 88 camaro. Originally it had a manual and v6. Before i bought it someone had switched in a 98 model 350 and 700r4. The motor has been converted to carb and hei. None of the wiring is done right. The fuel pump comes on when the switch is on. The battery gauge and fuel gauge is the only ones that work. What do I need to get everything to work right? Do I just get the sending units for a 88 camaro and find the correct wires? Would that work for oil pressure and water temp? I know the tach will not read right but is there any way to fix that without buying the gauges from a v8? Also even the heater controls dont work. What could they have done that makes it not work? Thanks guys
Brad
Old Dec 15, 2005 | 05:00 PM
3rdgenmaro's Avatar
Car: 88 IROC
come on guys. Im sure somebody can help me. Cant they?
Old Dec 15, 2005 | 06:12 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
you must have bought yours from the same guy i did. i had the exact same problems. i just bought aftermarket gauges to make it easy. what do you mean by the heater controls don't work? is it stuck on defrost?
Old Dec 16, 2005 | 11:14 AM
3rdgenmaro's Avatar
Car: 88 IROC
I hope that it is just a blown fuse. But you could turn the fan switch on and the fan wouldnt come on. Who knows what is up with everything on it. I guess I ll just have to wing it.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
