Distributer
Old Dec 18, 2005 | 01:31 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Distributer
What is the correct way to wire a 6al msd box, pro-billet distributer(#8361), and a blaster GM ignition coil(#8226).
Application is a 1989 chevrolet camaro. (5.7L engine MAF sensored - TPI, ecm #7165)
The reason I am asking this is because the stock distributer the car came with has a 4 wire (pin) connector going to it. The stock ignition coil had two wires going to it, one wire leading towards the tachometer. Yes, I'm sure. I realize it is simple to wire the 6al box to the distributer due to the special connector on each unit which mate together. But how would one wire those 4 incoming wires(4 pin connector) going to the distributer and the two wires going to the coil to the 6al box using this specific distributer? Would I even need the wires from this connector (4 pin) if all I'm doing is wiring 1 wire to an ignition source shown in the distributer instructions diagram in figure-13? Any answers will greatly help me out.
Thank you for your time,
Anthony
Old Dec 18, 2005 | 09:37 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
All MSD instructions are available from their website in .pdf format.
http://msdignition.com/1download.htm
Old Dec 18, 2005 | 10:03 PM
Dirtbik3r's Avatar
Ya... they have the diagram i'm talking about, but... what to do with the wires connecting to the distributer connector? They just say how to hook it up to a +12v ign. switch wire. Nothing about those other wires.
*EDIT
Ok, the distributer i have #8361 is a magnetic pickup hei distributer with the magnetic pickup connection which plusg directly into the msd 6al unit. With that being said... will it hurt to leave the other distributer wires disconnected?
The wires I'm reffering to are:
1) EST - wht
2) Reference - ppl/wht
3) Bypass - tan/blk
4) Distributer Ground - blk/red
Old Dec 18, 2005 | 10:43 PM
deadbird's Avatar
Engine: TPI 305/ v6
Are you still running the TPI ?
Old Dec 18, 2005 | 10:49 PM
Dirtbik3r's Avatar
Yes, I plan to use tpi. I've had the distributer lying around for a while and figured ide throw it in the camaro. Is it still possible to use it? Or should i go with another choice?
Old Dec 18, 2005 | 10:56 PM
deadbird's Avatar
Engine: TPI 305/ v6
You need this one for TPI/TBI instead of what you have now...
http://www.msdignition.com/dist_2.htm
Old Dec 18, 2005 | 11:57 PM
Dirtbik3r's Avatar
Too bad i bought that distributer in june... Now I have to sell it to someone. Thanks for the info Deadbird.
PS: if anyone wants a brand new #8361, get in touch with me...
db057
Apr 28, 2019 07:45 AM
Gunner242
Dec 25, 2015 04:49 PM
drptop70ss
Oct 4, 2015 09:44 PM
dusterbd
Sep 29, 2015 08:40 AM
pimprs
Aug 24, 2015 11:20 PM
