Everything died-again
Old Dec 18, 2005 | 09:49 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Let me start on what i have that is new:
ECM
Alternator
Battery
ignition switch
This is my post from a local f-bod site.
Anyone every changed the ignition switch on a 3rd gen? I had Joe Blow change mine about2 years ago and today i was going down the interstate and and everything just die . This is what i have so far:
New Battery
New Alternator
Dome Lights
Headlights
Dashlights
Fusible Links are good
Fuses are good
Grouds are good
Starter is on a manual switch (long story, check my post)
What i dont have:
Power to the fuse block
Power windows
**Power Locks** I can hear something clicking under the dash but the locks arent moving
Power to the ECM
Gauges
Brake Lights
Blower Motor Heat/A*C
My only guess from here is the shawdy job on the ignition switch. I have had it lock up on me a few times where i couldnt get the key out but fooling with it for a while i managed to get the key out each time. I need to change my Cylinder Lock and Key anyways but i cant afford a new column from where someone tried to steal it.
*I have taken the airbag, cover, sterring bezel, and etc. off to change the first Ign. switch but i didnt have a steering wheel puller so i put it all back together and payed someone to change it. I ahve a steering wheel puller now but i have never used it and dont want to get into something over my head.*
Old Dec 18, 2005 | 09:51 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I tried to backfeed through the fuse block from the battery and still got nothing.
Old Dec 18, 2005 | 11:40 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I just droped the steering cloumn and in the process the fuel pump primed and i got power for just one sec. As i was sifting through the wires it came on and off a few more times. I got to the ignition switch but i tried jumping all the wires across the harnesses at the ign. switch but got nothing. Going to take some pics. Trickster? Youve got me back and going several times. If you get me going this time i think that youll have to send me a bill
Old Dec 18, 2005 | 11:52 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
as it is now
Old Dec 18, 2005 | 11:53 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Down the steering shaft
Old Dec 18, 2005 | 02:05 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I dont know what i did but i can now backfeed through the fuse panel and get all my power acc. back including VATS and my fuel pump. Is there some kind of main fuse or relay? I have the complete column torn apiece now. I hooked up the new Ign. Switch but it isnt doing anything either so im assuming that my other one is still good.
Old Dec 18, 2005 | 02:10 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im also getting 12v through the 10awg red wire at the ign. switch. Is that the main feed to the ign. switch? Its the only one with 12 volts constant.
Old Dec 18, 2005 | 03:31 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I got the car cranked by backfeeding the fuse panel. I dont have a jack so i cant get under the car to see if any fuseable links are bad. Reading the schematics it seems that there is a few fuseable links around the starter and solenoid assembly.
Old Dec 18, 2005 | 10:18 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Well with all the help i finally got it fixed and running now.
Old Dec 18, 2005 | 10:52 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
They are right next to the battery. There is a distribution block that they all come out of. Usually, 2 lead to the starter, 1 leads to the altenator, and another leads to I believe the fan relay. You can access them from above the hood easily.
Old Dec 19, 2005 | 05:55 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Someone else told me that to but its not like that on my car
They were down by the starter though.
