radio horn and over head light
Old Dec 18, 2005 | 10:03 AM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
My radio, horn and over head light are not working correct I cheacked the fuses one was blow and I replaced it and still wouldnt work then I turned the radio *** I got static and then morris code!!! help!!
Matt
Ps cars out for paint
Old Dec 18, 2005 | 01:02 PM
Firebat's Avatar
did they all stop working at the same time?
Old Dec 19, 2005 | 12:06 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Sounds to me like a dead short. Replacing the fuse is not always the best thing to do when one blows. Fuses don't just blow for no reason. There was excessive amperage in the circuit and the fuse saved the wires from burning or a component from catching fire. Time to break out that voltmeter and start taking voltage drops. Also, before you do that, put in a false load in the fuse holder.
Old Dec 19, 2005 | 12:35 AM
Firebat's Avatar
The horn and dome light connects to the acc fuse, 20 amp. Radio hooks up to the radio fuse, 10 amp. So, i'm assuming you blew the acc fuse, 20 amp and you have something wrong with the radio.
Check out your overhead dome light bulb, maybe the light burned out and the blown up tungsten wire inside the bulb created a temporary or permanent short in the bulb. Could explain why you blew a fuse, or why you keep blowing them. If not that then try to hunt down shorted wires.
Now are you just getting static on radio stations, if so, you're antenna is disconnected to the radio. More than likely the big radio antenna wire n back is disconnected, check that out.
Old Dec 28, 2005 | 04:45 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Also when I get done driving and shut the car off and go to crank it, it doesnt start would this be because of a short or should I get my alt checked out?
Old Dec 28, 2005 | 05:14 PM
Firebat's Avatar
is your battery dead or not enough volts when you try to start? It could be a lot of things that would cause it not to start.
Old Dec 29, 2005 | 05:54 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
and also.. does it click? do nothing? turn slowly?
it could be heat soak on your starter
or the starter might not be shimmed correctly... alot of people just jam a starter up there as tight as they can get it against the flywheel, and it'll bind up now and again.
when i first got my car, it had a new starter in it... and it did it ALOT. it would just click, and do nothing.
i'd have to keep clickin it over to break it free, then it would fire right up.
it only seemed to happen after it was warmed up though, i'm guessing because expansion made tolerances tighter... it always fired up on the first try on a cold morning.
Old Dec 29, 2005 | 06:12 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
it would turn for a fraction of a sec then click and click and click and click....
Old Jan 4, 2006 | 07:24 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
FIXED! short in the cigarette lighter, freind disconnected it for me, put a new fuse in and its fine!
Old Jan 4, 2006 | 08:35 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Speaking of cigarette lighters,though not on our cars because of lighter location,is errant coins in the lighter cavity causing a short.i've seen it more than one.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Omega
Aug 10, 2015 12:46 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
