87 camaro wiring removal
Old Dec 26, 2005 | 01:18 PM
98_LS1's Avatar
Car: 87 camaro, 98 Z-28
I have a 87 camaro that had a LG4 305 4bll with the 700 R4. I need to figure out what wiring I can remove in order to clean up the engine compartment for this LS1 swap. I will be using a painless stand alone EFI LS1 harness with the 2001 computer. The main harness that exits the computer and runs through the passenger side inner fender to the engine compartment is all emmisions and engine control correct? What can I remove from that wiring mess and what do I need to keep? I will be using the factory gages but the painless harness should have the connections for the sensors and pickups. Anyone that has done this give me some advise so I don't screw anything up, the point is to keep the wiring clean and professional looking to be show worthy, thanks!
Mike
Old Dec 26, 2005 | 03:55 PM
98_LS1's Avatar
I figured it out, the harness is removed and ready for the painless harness. Disregard this thread
Old Jan 17, 2007 | 07:25 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
I was wondering if that worked out for you and what you needed to keep?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
