Trouble shooting Code
Old Jan 1, 2006 | 09:07 PM
Carlos Saez's Avatar
Car: Pontiac Firebird formula 92
Engine: 305 V8 TPI
I have a 92 Firebird Formula 305 V8 TPI
When I got the car I noticed that it had a hesitation when you got off the gas pedal. I checked the spark plug wires this were new as well as the spark plugs. I was looking in the forum and found out the how to look for trouble shooting coeds. The codes that I found were 45 and 22. I found the description of this code. Would the code 45 be that the oxygen sensor should be replaced or the low voltage shown on the code 22 makes that code come up?
Also If code 22 comes up were should I start to look for the problem?
Old Jan 1, 2006 | 10:04 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Code 22 describes the TPS as sticking, misadjusted, open in circut (bad conection), defective TPS, or defective ECM.
Code 45 describes both the TPS and Oxygen sensor as a possible fault.
I don't know how much you have driven the car since you've had it, but if it has been hesitating the same the whole time and not got any worse, I would guess it's the TPS. An oxygen sensor would continue to get worse over time. Unfortunatly, the TPS costs more to replace than the O sensor. Your local Auto Z should have a Haynes 82-92 firebird repair book that will locate the sensors for you.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Lmancha96
Sep 25, 2015 08:11 PM
