ACC Fuse Problem
Old Jan 2, 2006 | 01:41 AM
kolkane's Avatar
Car: 91 Z28
ACC Fuse Problem
For the last few days my acc fuse keeps blowin, the done light, maps lights dont work, door locks will only work if i use my alarm remote and the cig lighter was very hot when i tried to see if it worked, i also had some problems recently with my door locks locking and unlocking on there own. any ideas on what and where i should check? i was told to check the door lock relay ground, any other common spots i should check?
Old Jan 3, 2006 | 02:31 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
sounds like your alarm module might be getting a little tired.
Old Jan 4, 2006 | 09:41 PM
kolkane's Avatar
Car: 91 Z28
Turns out the cig lighter was pressed in and didnt pop back out, so i removed it for now and problem solved.
Old Jan 7, 2006 | 11:53 PM
chevy35086's Avatar
Car: Camaro z28 1986
Axle/Gears: 3.42's
lmao i had the same problem in my car i went through ten fuses before i figured it out.
Old Jan 8, 2006 | 02:32 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I know three camaros, an 86, 91rs, and 91z28, with the same problem.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
