Question-TPI and whats needed to make it run(no emissions)
Old Jan 2, 2006 | 02:13 PM
V8volvoman's Avatar
Car: volvo
Engine: 1978 305 w/TPI
Transmission: 1982 B/W T-5
I am in the middle of installing the TPI wiring harness on my 76 Volvo that doesnt have emissions equipment.
Will the engine start if none of the emissions equipment is hooked up for the TPI system? (i.e. EGR solenoid, A.I.R. diverter valve, canister purge solenoid valve, A.I.R. select valve)
Also....the transmission in the car is a 5spd and the computer is setup for a 92 camaro w/auto trans. What can I do about the VSS and the Gear Selector Switch outputs?
I know its a lot but if there are some links anyone has in mind where i may find my answers then please post them.
Thanks a bunch
Adrian
Old Jan 3, 2006 | 02:28 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
as far as the emissions, yes the car will run as long as you block the egr port under the plenum. You should be able to have a chip burned to delete the emissions so you don't get a trouble code.
I am not too familiar with the L98 computer programming so hofefully another member can dive a little deeper into this.
Old Feb 2, 2006 | 03:06 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Re: Question-TPI and whats needed to make it run(no emissions)
Thanks a bunch
Adrian
Hey Adrian, Its Anthony. (415)
I bet you dont have 12V switched power going to the fuel pump relay. (orange wire)
Attached Thumbnails Question-TPI and whats needed to make it run(no emissions)-c207.gif
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
matthew911
Aug 12, 2015 09:38 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
