HeadLights problem
Old Jan 9, 2006 | 10:25 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
HeadLights problem
when i turn on my headlights the pass side low beam light does not come on but when i flip it to hi beams it comes on what could be the problem and how can i fix it or do i have to take it to a mechanic
Old Jan 9, 2006 | 10:58 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The low beam element is burnt out.
The lows have a high and low element in them just like your turn signal bulb.
90% of the time.. a good smack on the lense will make the filiment regain contact for a short period of time.
Pop the hood, remove the retainer/trim 'ring' around the lamp (generally 4 torx screws.. only the top 2 really need removed, bottom just loose), pull/change the headlamp.. worry no more and drive safer at night.
Old Jan 14, 2006 | 01:15 AM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
do i have to pull them out foward or can i pull them from the rear case i got in a fender bender and have not got around to fixing them so i hope not foward
Old Jan 14, 2006 | 04:43 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
need to know which way to pull them
Old Jan 14, 2006 | 06:53 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There are 4 Phillips-head screws on the metal frame that holds the headlight bulbs in place. The upper two are easy to see and remove. The lower two are tougher. You'll need to pry the urethane of the front bumper cover down with a wedge to get to them. I'd suggest using a screwdriver with a magnetic tip so you don't lose the screws. To reinstall the frame I find it easier to bend the bottom two tabs at an angle. This allows getting the bulb and frame in easier. Once it is in you can reattach the electrical plug to the back of the bulb.
Lon
Old Jan 23, 2006 | 05:39 PM
antscrd's Avatar
Car: 91 z28/2014 charger
Engine: 350/ v6
Transmission: 700r4/ auto
to answer your question they hace to be pulled forward
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
