cruise
Old Jan 15, 2006 | 07:50 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
cruise
I have a question. will my cruise control still work even though I have switched over to carb? its an 89 camaro. does the cruise work on only vaccum or does the computer tell it what to do. thanks
Old Jan 15, 2006 | 12:19 PM
Vader's Avatar
The cruise control performs its own math, based on the inputs. As long as the VSS is still connected, and the other wiring has not been altered, it should work just as before. Of course, it requires a vacuum source to actually move the servo.
EDIT: Thsi is assuming it is the '89 in your profile.
Old Jan 15, 2006 | 12:40 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
yes this is. I don't know where it would get the vss from. I have no idea where it would get the vss signal from. thanks agian
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
ULTM8Z
Sep 16, 2015 09:15 AM
