Rear defrost might be working improperly.
Old Jan 22, 2006 | 09:07 PM
zrated57's Avatar
I have noticed that when I turn on the rear defroster, it will only defrost a few portions of the back window. About 10 or so of the defrost lines will work and the rest are not. What could be causing this slight annoyance and what is a cure?
Old Jan 23, 2006 | 12:54 AM
Vader's Avatar
The foil that is fused to the glass may be broken in several places. An analog meter or test light works well for diagnosing this. There are kits available to repair broken sections, complete with an oxidizing coating that colors the repair the same as the original foils.
Old Jan 23, 2006 | 07:06 PM
zrated57's Avatar
Would you know where I could get one of these kits or maybe send me a link? I don't know what you mean by coloring the repair the same as the original. Do the kits come in different colors or something? Also, if there is tint on the window will that make it harder to repair? THANKS
Old Jan 23, 2006 | 09:45 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Autozone carries them, made by Permatex I think around $15 bucks or so.
Old Jan 23, 2006 | 10:47 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You gotta pull the tint.
Old Jan 24, 2006 | 05:13 PM
zrated57's Avatar
SOB, I'd rather just forget about the defroster if the tints gotta come off. I read in my Chiltons book about how to repair it tho, seems fairly easy and painless. I also used a DVOM to check the voltage in the coil lines. Easy enough. Thanks much!
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
