Tachometer Question
Old Jan 24, 2006 | 11:56 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
Tachometer Question
In regards to early 80's instrument clusters (84 in particular):
Will the tach from a V6 car read correctly in a V8 car? Is there a dip switch to change from V6 to V8 mode? Or does a V8 need a different tach from a V6?
If they use different tachs, how can you tell the tachs apart?
Old Jan 24, 2006 | 09:22 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
v6 has 6000 rpm redline, some v8s have 5500, most v8s have 5000 rpm redline. Sorry no dip switch to set and the driver boards are different. HTH
Old Feb 1, 2006 | 05:38 PM
j dezzy's Avatar
Car: 87 TA
V6 to V8 tach
The resistor in a V6 tach is different than the resistor in a V8 tach. So a V6 tach cannot be used with a V8 engine. Now my question is, what ohm resistor can I put in my V6 tach to make it compatible with a V8 engine?
Old Feb 2, 2006 | 09:17 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Is it a resistor or cap that needs to be changed? Try a , I know it's been gone over before.
toones
Jan 6, 2016 06:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
