msd6al broken?
Old Jan 30, 2006 | 05:21 PM
magus92z28's Avatar
Car: 1992 z28
Engine: 350 L98
Transmission: 5spd
msd6al broken?
Im gona sound like a noob, but oh well. I got my car running back up again and noticed something quite intresting. the msd box that came with the car is not plugged in at all. What im wondering is how can u test if its broken? The cable that is suppose to connect it to the battery is cut and its not connected to the coil what so ever i will post pics. ty
Old Feb 1, 2006 | 10:01 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
The MSD box can be tested, I would pull it out of the car myself to test it on a bench but it can be done in-car.
You will need to supply 12 Volts from a battery (not a battery charger or small power supply - the MSD draws a great deal of current when it fires the coil).
You will need a coil to connect to the MSD's output. You can use an old distributor with a magnetic pickup to trigger the MSD box, or even an old speaker that you may have kicking around. Tapping the speaker simulates turning over the engine.
If you go to the Autotronics / MSD website you can download the wiring instructions for all their products - you'd be wise to have that on hand!
Old Feb 1, 2006 | 01:17 PM
magus92z28's Avatar
Car: 1992 z28
Engine: 350 L98
Transmission: 5spd
hey thanks a million gona get that done by the weekend =D
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
