fuseable link
Old Feb 2, 2006 | 09:51 PM
fbody396's Avatar
Car: 82 Z-28
Engine: 305 CFI
Transmission: auto
fuseable link
I discovered a burned wire that comes through the metal heat shield next to my starter solenoid. The wire or fuseable link must still be inside the tube. The burned wire piggybacks on the HOT side of the solenoid with a larger wire. Due to this burned wire the car will not start. What size wire, butt connector and fuseable link do I ask for at Auto Zone? Any ideas on how to easily fish the wire out of the tube so it can be repaired? Oh, it's an '82 Z-28, 305 CFI, auto trans. Camaro. thanks
Old Feb 3, 2006 | 04:03 PM
Vader's Avatar
Disconnect the battery and all the leads on the starter positive stud. You should be able to pull the wire bundle back and forth through the tube to expose on end of the broken one. You could also just push the new wire through the tube and forget the old one.
Old Feb 3, 2006 | 05:03 PM
fbody396's Avatar
Car: 82 Z-28
Engine: 305 CFI
Transmission: auto
Thanks! I'll give that a try.
Old Feb 3, 2006 | 06:54 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
There are a couple size wires going down there. I think the biggest one is 8AWG but I know there is a 10AWG that goes down there too.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
