I really need help......
Old Feb 3, 2006 | 12:17 AM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
First off, I did do a search, but I couldn't find anything that described my situation.......
My headlight motors don't do anything. They don't raise themselves or lower themselves. It is rather frustrating. I read alot of the threads on here, and most seem to point to the headlight switch or the headlight motor relay.
Well, I recently replaced my headlight switch with a junkyard replacement. But the headlight motors still don't work. However I do hear the relay clicking when I turn the lights on and off. So I decided to test the motors by hooking them straight to the battery. They raise and lower fine. So what should I replace next? The relay? I am at a loss.
I would greatly appreciate any help in this matter. It feels as if I am beating a dead horse, and I guess I am in a way......Sorry for that.
Thanks for your help!
Old Feb 3, 2006 | 12:27 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The relays switch the power from the battery on and off to the motors. Basically you blew a fuse/fusible link. Get a schematic, find the color wire, and trace it. Or someone will chime in where the link is.
Old Feb 3, 2006 | 03:09 PM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
In the wiring diagram in my Hayne's manual shows that there are fuses in an "underhood electrical center." But I see no fuses anywhere. Is the manual wrong, or am I just retarded and can't find it? I have the V6, if it helps.......
Old Feb 3, 2006 | 03:19 PM
Car: 86 T/A
Engine: HSR 355
The fuses are probably fusible links, they are just short pieces of wire that are designed to burn up if the current rating is exceeded.
Find out what pin of the relay supplies power to the fan and check for voltage. If there is none then follow it back to the battery until it does have voltage.
Old Feb 3, 2006 | 06:56 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Do you know where the relay is? Do you have an electrical meter?
Ben
Old Feb 4, 2006 | 01:31 PM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
I do know where the relay is, and I can get a electric multimeter.
Old Feb 6, 2006 | 02:51 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
First, I don't have a firebird so I'm doing a little guessing but all relays work the same and they are very easy to test.
You should have 4 or 5 wires coming from your relay. 2 of them you be larger guage wires (thicker). These are the supply for the motor. One of the other 2 or 3 wires should be black, if not try to figure out which one goes to ground. If you can't figure out which is ground, don't worry we can test for that.
Let me know how many wires are coming out of the relay and what color they are and I'll tell you which ones to test. You'll need a paper clip as well.
greggie82
Wheels and Tires
Jun 20, 2013 02:15 AM
CAMAROBEAV
Jun 17, 2012 11:51 AM
CAMAROBEAV
LSX and LTX Parts
Jan 15, 2012 11:17 AM
Scott1012
Mar 12, 2010 02:57 PM
knightbandit88
Northern California
Oct 26, 2009 07:22 PM
