Power to Manual Windows, Please help...
Want to go from Power Windows to Manual Windows. Perfer manual, anyone have a link on the process? Please Help......
Thanks,
Thanks,
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: Power to Manual Windows, Please help...
How much weight does this conversion save? other than that, I can't see any point.
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
If you dont mind the minimal effort of rolling them down on occasion, I dont see the point in power windows, especially in a non daily driver.
DIdn't know how easy / hard this is. Prefer manual as car will be track only, and don't want to worry about power windows not going down or up for that matter at the track.
Anyway any help / advice would be GREAT.
Car: 1990 Trans Am
Engine: Lb9
Try some searching, I know I had found something at some point about how its almost the same process as replacing a power window motor, only instead of using a new power window motor, you install the manual actuator. Past that you would just need the parts.
Car: 1991 RS Hardtop
Axle/Gears: 3:23
I did the conversion the other way, from manual to power. It wasn't too hard, like the post above says, you can just follow the step by step conversion backwards essentially.
I have two manual window cranks if anyone is interested to sell... just let me know. here are the directions i followed...
http://www.p71interceptor.com/thirdgen/powerwindows/
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The best type of hardware (IMO) is small 10mm nuts and screws. Just like the factory ones used all over the door hardware. Once you punch the center from each rivet and drill the rivets out - the 10 mm nuts/bolts fit the mounting holes real well.
This picture shows the holes you will need to use when mounting the regulators to the door.
With Power Windows , The 2 FRONT rivets holding the regulator in place are located in the holes closest to the FRONT of the car (See yellow circles).
With Manual windows, The 2 FRONT rivets holding the regulator in place are located in the holes closest to the BACK of the car. (See yellow circles)
The other 2 regulator mounting holes ( red circles ) will line up with the right door holes once the front 2 are in set in the right place (depending on the swap. )
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
i doing this swap too, i have 2 whole doors with manual windows, and the ones on the car i just got are power and they dont work, plus i hate power windows for some reason, just something else to break... to me anyways...
but its nice to know its a straight forward swap...
Car: 1992 Camaro RS
Engine: 565 Big Block Chevy
Transmission: RS Jerico 5 Speed
Axle/Gears: 9 inch ford with 3 inch gear
Hay i live in iowa does any one have the parts to convert my power windows to crank. Buy or trade i have a punch of interior parts off of my 92 RS
1992 Trans Am
May 10, 2023 07:19 PM
sailtexas186548
Aug 24, 2015 10:11 PM
body, camaro, comparison, conversions, convert, fbody, gen, manual, power, replacement, saving, thirdgen, weight, window, windows
