Reverse Glow Gauges: Hard to see the needles
Old Mar 7, 2010 | 08:01 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Hey guys/gals,
I have installed a set of Auto-concept Z reverse glow gauge overlay's in my 87 IROC and of course with all of the normal bulbs taken out (to get the maximum effect of the reverse glow) I find it hard to see my needles.
Has anyone found a solution to this small problem? I know I can put all of my white 194 bulbs back into the cluster but that sort of washes out the reverse glow effect.
I was thinking about getting a couple of UV Blacklights (194 wedge types) and some Blacklight UV paint ...install the blacklights in the cluster, either in the stock locations or maybe somehow remote mounting them so they shine down on the gauge faces to illuminate the needles.
And ideas?
UV Black light bulbs (194 wedge type)
http://cgi.ebay.com/ebaymotors/UV-Bl...Q5fAccessories
Black light UV paint
http://cgi.ebay.com/BLACKLIGHT-UV-PA...item3c9c2ccc1a
Stan
Old Mar 8, 2010 | 12:46 PM
87ROCZ's Avatar
Re: Reverse Glow Gauges: Hard to see the needles
Nobody's tackled this problem ?
Old Mar 8, 2010 | 03:37 PM
DVR408 88 iroc's Avatar
Car: 88 iroc
Engine: 5.7 TPI
Transmission: TCI Street fighter
you can take the needles out and paint them any color like red..be careful tho cuz the needles break easy
Old Mar 8, 2010 | 04:07 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Painting needles adds unwanted weight to them. They typically will not read correctly after painting them.
Old Mar 8, 2010 | 04:22 PM
Car: 88 iroc
Engine: 5.7 TPI
i sprayed mine and they work fine
Old Mar 8, 2010 | 04:35 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
just paint a light coat with rattle can and you should be alright..
Old Mar 8, 2010 | 07:10 PM
87ROCZ's Avatar
Thanks for the replies... I have already painted my needles red with a light coat of Testor model paint and have no bad effects (my speedo cable gets sluggish after about 1 hour of continuous driving, could be the cable or maybe the gear in the transmission..will find out later this year)..
My question is ... has anyone installed these Autoconcept-Z reverse glow on an older 3rd gen (ie: not the newer 90-92 cluster with the backlit needles) and solved the issue of not be able to see the needles very well at night?
Old Mar 12, 2010 | 03:15 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I always wanted to try a phosphorous paint and add small black lights in there somewhere, similar to what I believe the c5 vettes had going on. I just painted my needles red and use indiglo gauges. After going back and forth between those and reverse glows, I opted for the indiglo because of the needle issue. Never did use the reverse glow set I bought
Veaceonee
Sep 29, 2016 08:15 PM
69GTOby
Apr 18, 2016 02:34 PM
Breazlan
Sep 25, 2015 11:20 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
