Rough Idle
Old Feb 3, 2006 | 07:14 PM
Meinherr49's Avatar
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
Rough Idle
My Car has developed over this Past week a Rough Idle . It even Stalled on me when I put it in Reverse to back into a Parking Space . I know there could be Numerous Reasons for this Condition , but I was Hoping to Isolate it down a Bit . Maybe Fouled Plugs ? Distributor Parts ? Injectors are CLEAN , no Prob there . Idle Air Control Valve developed a Different Voltage due to >? Just Needs a Full Tune Up ?
The Car Runs Great , but when I am Idling at a Stop sign , my Tach is a Little to Jumpy for my Tastes . It usually was Right on 500RPM's awhile ago . I am use to a Rock Hard Idle on most my Cars , but this one just dosen't FEEL RIGHT Lately . Any Suggestions to how I might Solve this Problem ? Any input would be Welcome . Thanks ..........MARK
I do have Flow Tech Headers on this Car , and my OX Sensor works OK BTW .
Old Feb 3, 2006 | 11:10 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Check your plug wires. Especially the coil to distributer wire. Other than that, start taking voltage drops from the distributer and verify coil resistance.
Old Feb 4, 2006 | 06:28 PM
Meinherr49's Avatar
Rough Idle
Thanks for the Response Dirtbik3r . I went out and removed each Spark Plug Wire and noticed a little Corrosion on 4 of the wires at the Distibutor Terminals . I live near the Ocean and Salt Air Corrosion has always been a Problem for my other Cars . I Cleaned the Contacts , and Put the Wires back on . When I started the Car and it warmed Up , my Tach needle was Right on 500 Rpms in Drive . No Stumbling or Erratic Tach Movement in Idle . Thanks for your Advice Bro . An Easy Fix that did not cost me Money . I Owe you a BRAU for that one Dude ! LOL
By the Way , here is a Pic. of my Old Porsche Unleashed Online Racing Team Roster the [XR] 's . I hope to Own a Porsche one day before I die . To me , the Best Car Ever made .
Signed........[XR]Herr
Old Feb 4, 2006 | 06:30 PM
Meinherr49's Avatar
PIC.
Sure had Fun in the day with my Buds Online.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
