auto dim mirror question
Old Feb 19, 2006 | 09:30 PM
zammer's Avatar
Car: 1988 T/A GTA
Transmission: 5spd
Do you need signal from the back-up switch(manual trans) in order for the auto-dim rearview mirror to work? The mirror lights up, but doesn't move, does that mean the mirror is junk?
Old Feb 20, 2006 | 06:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the mirror is hooked up to the back up lights.
JamesC
Old Feb 20, 2006 | 08:35 PM
zammer's Avatar
Car: 1988 T/A GTA
Transmission: 5spd
ok, but that doesn't answer my question....
Old Feb 21, 2006 | 06:19 PM
tagta189's Avatar
You can forget the disable wire going to the backup switch.Leave it unhooked.It should function just fine without it.All you need is power and ground.The main power lead goes directly to the switch.The main ground will go to alot of places(if you take it apart to look)and the main disable trigger wire I think just goes to one tiny resistor.Forget that wire leave it open.It should work perfectly.Mine has for quite a few years.You might need to relube the worm gears and replace the old dried out drive belts.While you have it apart clean the little windows for the two photo-sensors.Good luck.It's a ridiculously overcomplicated mechanism,but damned if it doesn't work like a charm,it seems to know right when to switch back and forth.Just don't get so amazed watching it do it's stuff that you get into an accident.
Old Feb 21, 2006 | 07:25 PM
zammer's Avatar
Car: 1988 T/A GTA
Transmission: 5spd
thanks for the help...
would you have any pics of the mirror apart?
Old Feb 23, 2006 | 12:59 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I have 2 auto dimming mirrors.One is the older style but I don't have the wiring harness for it.Anyone have an idea where to get one?The second mirror is a later style with an of-min-max switch on the button.I have the harness for this one.It goes to a 3 wire plug(solid green-solid black-light purple w/black stripe).I'm ssuming the black is ground but which would be power the solid green or the purple/black stripe.Also one would go to the reverse switch but tagta89 said that isn't neccessary for the mirrior to function.It just won't un-dim/turn off when you go shift into reverse('83 Z28 auto).
jaridjohn
Jul 8, 2024 03:49 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
redmaroz
Aug 16, 2015 11:40 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
