Power door locks, continuously locking and unlocking
Old Feb 25, 2006 | 11:41 PM
Mandy`s 86 TA's Avatar
Car: 86 Trans Am
Transmission: auto
Hi, I need help with this, my door locks won`t quit locking and unlocking and drained my battery. I took out fuse 11(20 Amp-Yellow)- Glove box lights; Cigar lighter; Hatchback Lid Release; Horn Relay; Interiot Lights;Power Antenna; Power Door Locks; Radio/Digital Clock; Computer Command Control--- to make the locks stop and charged the battery. I can`t get it fixed right now (what`s wrong with it?) and I have to get it inspected on Monday, can I drive it without that fuse..Fuse 16(35 Amp-Circuit Breaker...also stops the door locks. What about taking that one out instead...Can I disconnect the power door locks? As you can tell I don`t know too much about cars, but I need to drive it...Do you think it`s a short? When I took fuse 16 Circuit breaker out and put it back in it sparked, is it supposed to do that? Thanx for any and all info
Old Feb 26, 2006 | 02:25 PM
bigbird89's Avatar
Car: 86 Firebird
You're probably right about it being a short. Check your wires and see if any of them have bare spots where the insulation could have rubbed off.
Old Feb 26, 2006 | 02:52 PM
Car: 86 Trans Am
Transmission: auto
Thanx bigbird, but can I drive it without one of the fuses that I mentioned in my post...I won`t mess up the car or anything, will I?,,,Can I disconnect the door lock and unlock switches? I`m trying to do something temporary so that I can use the car till it`s fixed.
Old Feb 26, 2006 | 04:41 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
sometimes the fuses will spark a little. but you can always try it. i would disconnect the circut breaker one, run the car for a few, and see if you notice any changes, ie... temp etc... and if not, go with that for now.
Old Feb 26, 2006 | 05:19 PM
bigbird89's Avatar
Car: 86 Firebird
Personally, I would just unplug the electric door locks so that I wouldn't run the risk of damaging some other part of the car, but that's just me.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 23, 2015 06:33 AM
stalkier
Aug 21, 2015 01:54 AM
