cruise control???
Old Feb 27, 2006 | 11:17 AM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
cruise control???
I never use my cruise control so I want to pull it out, just to clean up the engine bay a little more. Just wanted to know if it will affect anything on my car. I was told it might mess up my speedo, is this true? Any imput would be great, Thanks
Old Feb 27, 2006 | 03:27 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
On 90-92 the speedometer and the cruise get separate signals from the ECM, removing cruise won't affect the speedo. I don't know about the cable driven speedos.
Old Feb 27, 2006 | 03:38 PM
Car: 94 25th TA
Engine: 355LT1
It would be on an 87 firebird. LG4/700r4
Old Feb 27, 2006 | 05:57 PM
Car: 94 25th TA
Engine: 355LT1
Ok I did some searching and found out that the ball thing under the canister (Orb of Power) that the cruise control go to is also used to control the vents inside. If i were to remove that is there still a way I could get my vents to still work.
Old Feb 27, 2006 | 08:02 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
without it the air controls would still work, but, when you get on the gas & loose vacuum they would go to the default position of defrost. at cruise & idle the controls would work fine.
Old Feb 27, 2006 | 08:10 PM
Car: 94 25th TA
Engine: 355LT1
alright then I guess ill pull it out. Thanks for the replies
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
