Code ?
Old Mar 1, 2006 | 04:44 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Code ?
I have an 87 f bird. 5.0 carb. Code poped up 41. My book give problem , then in back gives diffrent problem. So which one is right?
Old Mar 2, 2006 | 09:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It means that there is no distributor pulse reference to the ECM at specified engine vacuum. You could have a problem with either the MAP or VAC sensor.
Old Mar 3, 2006 | 04:11 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
OK, well thank you. To narrow it down, which one of these would make it run like crap and surge. And what could be damaged easily when someone is replacing the starter.
Old Mar 4, 2006 | 12:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Either one of them would do that and it could be that one of them is just disconnected or the vacuum line to it is broken or has come off. Neither one of them is located near the starter. However the vacuum line may have been pulled loose by someone disconnecting the battery.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
