raido help
Old Mar 4, 2006 | 07:06 PM
blksiryder's Avatar
Car: 1992 camaro rs
Engine: 3.1
raido help
i need help. i have a 92 rs v6. some one cut the wire harness to the raido. i have the speaker wires good. but i need help with the power/ground/acc/dimmer/and lights if some one could take a pic and label the wires for me or send me a pic of the diagram it would be a big help
Matt
Old Mar 5, 2006 | 10:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Matt,
Which radio system did you originally have in there, the standard radio or the Delco-Bose amplified system?
Old Mar 11, 2006 | 12:26 AM
Droptop_Z's Avatar
Car: 88z
Transmission: t-5
I have a similar problem with my radio. When I bought my camaro the memory presets would not save when i shut the car off. I pulled the radio and noticed it was put in place because of a aftermarket radio was more than likely in there before. My rpo code sheet says that the car came with a cd player u1c, but when I hook up the cd player it wont even power up. I hooked this cd player up to my other camaro that has the original tape deck in it and the cd player worked great. I tried the tape deck in the other camaro and no luck. Anyone know what would be going on here? Thanks
Old Mar 13, 2006 | 07:40 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I would invest in a 'reverse harness'. Just drop by someplace that does car audio, tell them your story and tell them you want a reverse harness. What you get the a replacement "stock" harness, mach up colors, solder and heat shrink or good crimps and you're golden.
Samdweezel05
Interior Parts Wanted
Jun 8, 2008 06:16 PM
91rsowner4life
Car Audio
Feb 27, 2006 08:39 AM
JimBow
Car Audio
Oct 27, 2000 09:42 AM
