No spark 5.7 TPI
Old Mar 11, 2006 | 07:43 AM
87T-TopBird's Avatar
Car: '87 Firebird
No spark 5.7 TPI
Hello all;
Just finished putting car back together (took out dash, interior, put in T56) I try to start the car and no spark. Everything worked fine before i did the tranny swap so i'm leaning toward a wiring problem (instead of pickup, dist. module, etc.) since i took the dash out. The only wiring i changed was at the neutral safety switch. I did put on a new coil but didn't help.
My question is: are there a couple of specific wires i can chase to find out if something is disconnected? ie, power wires for the coil, where do they go? is there something simple i may be missing (all fuses look good, EVERYTHING else on car works, lights, gauges, fuel pump, wipers, etc)
Distributor cap is fairly new, car doesn't even try to start, just endlessly turns over.
Any and all help is appreciated
Kyle
Old Mar 12, 2006 | 07:28 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THIS QUESTION SPARKS AN ANSWER
<CENTER><B>
Yup it does sound like a wiring problem.
Disconnect the two terminal connector at the
distributor. Then turn the key to the RUN position.
Are you getting 12 volts at both sockets on this connector?
</FONT>
</B><FONT COLOR=F3399><H5>“If people drove any slower they’d be going backwards”</FONT>
<FONT COLOR=FF66FF>NINÅ</H5></FONT>
<P>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE></CENTER>
Old Mar 12, 2006 | 10:03 AM
Car: '87 Firebird
thanks for the reply nina;
After checking all the wires and everything checking out, i took the dist. module and got it checked and it failed! Weird though that it would go bad by just sitting for 4 months!
Old Mar 12, 2006 | 07:30 PM
crapper_mekanic's Avatar
Car: 1985 Trans Am/ Recaro w/webbed headrests (AS5)?
Engine: Code F
Transmission: 700, shame, ain't it?
Axle/Gears: 3.27 Borg-Warner posi
believe it or not
I have heard of this more than once when the dashboard is removed and re-installed, don't ask me why, but apparently it does happen...
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
